Multisim and Ultiboard
MCU only output 2.5V
I have setup a PWM output on PortA. The micro is only outputting 2.5V.
(2,948 Views)
Hi JRail,
I was not able to properly see your circuit since you haven't send the MCU workspace.Basically I can only run your circuit with no code associated with that.Can you send the MCU workspace as well and also explain what output you expect to see.
Leila F.
NAtional Instruments
(2,906 Views)
