Multisim and Ultiboard
LDR not found on Multisim 11.0.1
Where i can find LDR (light dependent resistor) on multisim 11.0.1 ??
Best Regards,
Exodia Necross
(23,898 Views)
Accepted by topic author exodia_necross
Multisim doesn't have a LDR but you can use a Votage Controlled Resistor instead, the input for this component is voltage but you can let it be light.  Multisim doesn't really simulate light.  If you need a LDR to draw you schematic, go through Component Wizard, you can draw anything.
Tien P.
(23,895 Views)
Thank you for replying. How to use Component Wizard to create LDR ?? Please hep !!!
Best Regards,
Exodia Necross
(23,877 Views)
Have a look at this tutorial:
http://zone.ni.com/devzone/cda/tut/p/id/3173
In the first step, you should select "Layout" only because you will not be simulating this component.
Tien P.
(23,859 Views)
Ok. Thank you very much. I'll do it. 🙂
Best Regards,
Exodia Necross
(23,829 Views)
