12-14-2010 07:03 AM
Solved! Go to Solution.
12-14-2010 08:19 AM
Multisim doesn't have a LDR but you can use a Votage Controlled Resistor instead, the input for this component is voltage but you can let it be light. Multisim doesn't really simulate light. If you need a LDR to draw you schematic, go through Component Wizard, you can draw anything.
12-14-2010 06:51 PM
12-15-2010 07:51 AM
Have a look at this tutorial:
http://zone.ni.com/devzone/cda/tut/p/id/3173
In the first step, you should select "Layout" only because you will not be simulating this component.
12-16-2010 04:55 AM
