Multisim and Ultiboard
Is noise analysis enabled in Analog Devices version?
I just installed the Analog Devices edition of Multisim 11.0 and immediately went to check to see if some AD op amp noise models that give funny results on other spice programs work on Multisim.
However, under the analysis menu there's no "noise analysis" where the documentation says it should be. Is this feature disabled in the AD edition? Is there another way to do noise analysis in the AD edition?
Andrew
(2,581 Views)
Hi andrewjm:
Noise analysis is not available in the current Mulitisim Component Evaluator Analog Devices Edition. Thanks for the feedback that information that noise analysis would be useful. It will be considered for a future update of the product.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(2,553 Views)
