12-16-2008 12:11 PM
I am a long time Ultiboard V4.83 user - and I am currently evauating version 10.1.
I have loaded a V4.83 job into V10.1 just fine. I use Orcad V9.2 for schematic capture and I am just trying to figure out how to re-import netlists into Ultiboard after modifying the original schematics.
If I use File/Open/ and choose 'Calay netlist files' a new project is started - unplaced and unrouted of course!
Ideally there would be a 'Calay netlist' option under the File/Import/ menu...
Is there an easy solution?
12-18-2008 08:04 AM
12-22-2008 07:17 AM
Hi TimG,
I was just wondering how you were getting on with the evaluation of Ultiboard 10.1? I hope your well and have a good festive period.
Kind regards,
12-24-2008 07:55 AM
I'm generally impressed with the latest Ultiboard. I get to use various CAD systems in my work for various clients, and Ultiboard compares well.
To clarify, the issue is importing schematic netlists into an existing PCB design. Ultiboard V10.1 only seems to accept importing a schematic netlist in Ultiboard's own format, so, as an Orcad Capture user, it is necessary to use a translator program to reformat an Orcad generated netlist for import into Ultiboard.
The frustrating thing is that Ultiboard will accept other formats when loading a new job. I am now aware there is a workaround involving loading the revised schematic netlist as a new job and then pasting the new job into the existing job, overwriting the nets.
Version 5 Ultiboard had a neat Windows 98 utility (Tango to ULTIboard.exe) that translated Tango format schematic netlists into Ultiboard .net and .cmp format files. Unfortunately this program won't run under XP, even with Win98 compatability settings. So I'm writing a new translator program myself...
BTW, Tango is a better format for importing netlists than Calay which doesn't accept the underscore character in net names.
Next step in the evaluation of Ultiboard is to benchmark the autorouter against Specctra....
Happy Holiday everyone!
Tim.
12-24-2008 10:05 AM
It seems like some people were able to get EWB 4 running in Windows XP using DOSBox. If you still have EWB 5 around you may be able to run it under DOSBox as well.
Here's the thread about DOSBox and EWB4:
http://forums.ni.com/ni/board/message?board.id=370&thread.id=5030
Here's where you can get DOSBox:
http://www.dosbox.com/download.php?main=1
05-19-2009 11:05 AM
I have OrCAD 15.7 and I and tried to import Calay netlist file but was unsuccessful. Orcad files (*.max, *.llb), the *.max is OrCAD layout file suffix. The *.MNL is the net file.
Could you let me know what's the right one for the format?
02-17-2010 05:09 AM
02-10-2011 12:53 PM
I use Orcad 9.x to capture schmatics, as does our entire lab.
What netlist that Orcad Schematic Capture generates will Ultiboard accept and call patterns from the pcb footprint field?
02-11-2011 05:07 AM - edited 02-11-2011 05:09 AM
Maybe one of the NI tech support people could give us an update on the Orcad netlist import issue?
We eventually decided that another manufacturer's software better met our needs Email me via www.t-g-c.net if you need any more information.
Tim.
