05-21-2016 06:03 AM
Hello. I'm trying to desing a circuit on Ultiboard but i couldn't find Atmega 328p 28 pin connector. It has width about 7.5-8 mm. But all of dip sockets in the Ultiboard has bigger width. What should i use? THANKS IN ADVANCE.
Solved! Go to Solution.
05-23-2016 06:18 PM
If you cannot find the component you can always create it follow in this two documents:
http://www.ni.com/tutorial/3173/en/
http://www.ni.com/tutorial/5631/en/
Is pretty easy. The most complicated part is to get the SPICE code.
02-16-2017 01:18 AM
Hello everyone,
I am also interested in ATmega328P footprint or ATmega32u4, is it already avaiable out of box?
02-17-2017 09:04 AM
It seems that the component is not the DB yet, you will have to use the links above to create it.
Regards
