09-02-2010 07:34 PM
I have the following circuit and want to know how I can simulate it to check and see if the motor turns. Newbie thanks
09-10-2010 08:33 AM
The motor used in the circuit is not an animate part, it won't show you if the motor is turning or not. To test your circuit, you should use the scope and see if you get the right signal that will turn a motor.
10-25-2021 12:16 PM - edited 10-25-2021 12:22 PM
Поскольку в MS угловая скорость есть напряжение на валу электродвигателя, то можно засечь по пробнику напряжения поворот вала туда-сюда в вольтах-fv
