01-21-2011 08:24 PM
Hi there. I am trying to add a component to Multisim 11. It is the Motorola MC3418P Continuosly Variable Slope Delta Modulator/Demodulator. I can't seem to find anything to help me on this so ANY help is greatly appreciated.
01-25-2011 09:15 AM
If you need the component for schematic purpose only, you can go through the Component Wizard to create you own symbol, this option is under menu Tools>>Component Wizard. If you need this component for simulation, you need a SPICE model, I did a quick search and unfortunately, I was not able to find one.
01-27-2011 06:25 AM
Hello! Where can i find SPICE files for 2sc2073, 2sc5200, 2sa940, 2sa1943, 2sc9014, 2sc3200 transistors?
01-28-2011 01:35 PM
Most SPICE models are created by the component manufacture so you should check their website.
01-28-2011 11:24 PM
Unfortunately, I do need it for simulation. I guess I'll keep searching around. Thanks!
