Multisim and Ultiboard
Help with Led failure
Hello i'm new in the forum, i'm from Argentina so I'm sorry if I don't make myself understood.
I'd like to know if there's a way to show the failure of a LED in multisim as the lamp does.
In a DC circuit, just to test I put a 15V battery and a green LED connected to each other (in this case the LED must fail) but in multisim the arrows that show the LED status are still on, like the LED is functioning normally.
In the case of a lamp, if I put a 4V-0.5W lamp, it will crack the filament and won't show it on as if its working fine (when the lamp is working fine its all yellow)
So that's my question, is there a way to do the same with the LED?
This is for educational purposes, that's why I need to show that the LED won't work or will crack.
Regards.
(3,412 Views)
(3,380 Views)
