09-30-2010 01:50 PM
Unusual problem. One of the components in a Multisim 9 schematic, a 74LS74, is not being transferred to Ultiboard. It is dropped completely from the Ultiboard netlist, but does still appear in the Multisim netlist. The all too common message 'Virtual component not transferred', but there's no indication what component it's referring to. The 74LS74 seems to be a real component in every other sense. How can I fix this? Thanks very much. jk
Solved! Go to Solution.
10-01-2010 01:33 PM
Hi there,
There's an easy way to find out which components in your circuit are virtual. Try this:
Hope that helped.
10-01-2010 03:24 PM - edited 10-01-2010 03:24 PM
I took a look at your design and I guess what I said earlier does not answer your question. To fix this problem, try this:
This looks like a problem with Multisim. Was this design created with an older version of Multisim? Do you remember how you created it?
Thanks.
10-01-2010 05:16 PM
One of the other good guys there at NI made the following suggestion which happened to work beautifully:
Double click on the 74F74N select the "Variant" tab, under the "Status" column, change the setting from Excluded to Include, I am not sure what caused this problem, I've modified the component and the file is attached.
