01-09-2011 04:31 PM - edited 01-09-2011 04:35 PM
I was Designing a variable regulated power supply simulated my circuit in multi I faced many problems I was able to solve sum of them but sum of them still remain used positive regulator LM317k the output waveform observed is shown in the figure there is transient curve before the constant voltage???
and after adding capacitor to act as filter the output is constant without any ripples????
there should be sum ripple but graph shows constant voltage,why is this so???
and im using multisim 10.
im attaching my schematic and graph,plz take a look and try to figure out a way to solve these problems
01-09-2011 04:33 PM - edited 01-09-2011 04:36 PM
and im using multisim10
01-10-2011 06:44 AM
Try adding a load to the output? Can you attach your ms10 file? It's easier to evaluate the actual circuit.
01-10-2011 10:25 AM
these are the ms10 files
why would adding a load would make any difference when we have voltage regulator in the circuit??/
01-10-2011 12:04 PM
01-10-2011 12:05 PM - edited 01-10-2011 12:07 PM
Connect the scope probes to the input of the regulator and vary the load to see the effects of load on the filter.
