Multisim and Ultiboard
Design Tollbox ->Visibility suggestion
I use MS14, but I belive it is the same with versions 13 and12/
there is something I do not like - take a look at the picture
why Labels and Values are united as one check box.
what should I do if I need Labels off and Values ON or vsvr.
same goes to Attributes  and variants
thanks
Michael
(3,936 Views)
Hi Michael,
You should be able to get what you are looking for in two other places, the sheet properties (under the Options menu), or the component display settings (found by double-clicking the component and looking under the Display tab):
Unfortunately the options in the design toolbox seem to be out of sync with these. I have filed a defect report for R&D to look into.
Let me know if this helps,
Jeff
(3,912 Views)
hello jeff, thanks for fast response.
sure. Lets   hope R$D  will do something about it.
thanks
Michael
(3,907 Views)
