05-30-2010 06:40 PM
I'm currently working on Power System project, which aimming to designing Power System Stabalizer that will damped oscillations created when there is a small changes in load in the network. I got the model done in Simulink and now trying to convert it using SIT into LabVIEW.
I able to map all the data that I want to control and link the output graphs to LabVIEW using SIT. Now, I wanted to convert the Simulink model to DLL type file, but while I was trying to convert the model I build in Simulink into nidll type file using R-T Workshop an error popped out and it is said it causes by the "Phasor Type" in the PowerGUI block in Simulink. The error says in order for me to continue the conversion, I need to change the Phasor Type in the PowerGUI to other parameters, I tried it but the model no longer producing the similar result I wanted. I was wondering if anyone know any method to convert a Phasor PowerGUI block in Simulink to nidll type file?
05-30-2010 08:04 PM
05-30-2010 09:27 PM
I post this question before in NI Discussion Forums : Most Active Software Boards : LabVIEW : Converting Simulink model using Phasor PowerGUI to DLL file
but a guy name Jeff Bohrer suggest I should post it here on Design and Simulation board.
My previous post was here.
06-01-2010 01:27 PM
Hi tebu,
Could you post a screen shot of the error you are getting?
Thanks!
06-01-2010 03:23 PM
Here. Currently, Solver options Type = Fixed-Ste. Solver = ode14x (extrapolation). Extrapolatino order = 1.
06-01-2010 04:50 PM
Hi tebu,
We'll work from the thread on the LabVIEW board instead.
Have a great day!
