Multisim and Ultiboard
Cant get to install
Cant begin install of Multisim. I try to start the install and go thru the program and i get this cc.JPGi am using the trial version as my mydaq is on this way with the subsription service.
(4,678 Views)
The path in the image is truncated, so we cannot tell where it is pointing at. Did you download ELVISmx?
(4,670 Views)
Don't need elvismx. I try to click cancel and its supposed to continue installing yet it doesn't.
(4,654 Views)
Hi All,
Why you said that it doesn't. Did you check in all programs for the Software? What happens when you hit on cancel?
Regards
(4,630 Views)
I've had the same problem trying to install NI.
Here's what happens... download the installer, install the zip file, unload the zip, that opens the menu for National Instruments circuit design suite 14.0, I go to install the N.I suite 14.0...
and the pictures here tell the rest.
(4,435 Views)
Hi All,
Where did you download the installer? It seems that something is missing, try directly from National Instruments web site.
http://www.ni.com/download/ni-circuit-design-suite-educational-edition-14.0/5254/en
Regards
(4,411 Views)
