05-14-2011 10:56 PM
Currently I get this error message on both of these applications. Would greatly appreciate if there's an answer. Currently using Windows 7 x64, Tried 64-bit versions of the applications and still I get the error. Thanks.
Solved! Go to Solution.
05-16-2011 08:48 AM
Hi George,
Can you please check if you have logged in as an administrator to the computer? If you haven't please do the installation again and if you still see the error if it is possible for you try installing it on another computer. Please let me know if you made any progress in the installation.If you did not please also send the installation log file.Here is the link that shows how to find NI Installation Log Files.
http://digital.ni.com/public.nsf/allkb/ACAA8550534EA407862574B80074DEDF?OpenDocument
Leila Feyz
05-16-2011 12:58 PM - edited 05-16-2011 01:03 PM
I'm the administrator of the computer. Here is the log file you asked for. Thanks
05-16-2011 12:59 PM - edited 05-16-2011 01:01 PM
I could install it in a virtual XP in the same computer. But it's not practical.
05-16-2011 02:40 PM
George,
Thank you for the file and the update. I will work on the log file to find out more about the problem . Can you please also verify for me that does the
C:\Users\Public exists on your computer? Take a look at this KB. Although it is for VISTA it might help you.
http://digital.ni.com/public.nsf/allkb/24E09BDC314EB93A8625758D004ECBC6
Leila Feyz
05-16-2011 04:27 PM
Precisely, it worked. There was a folder missing inside public folder, it's name should be "Documents" and it wasn't created at the install of Windows. Thanks for everything.
05-17-2011 08:00 AM
George,
I'm glad it worked.Thank you for letting me know.
Leila Feyz
