03-10-2016 12:06 PM
I recently purchased Multisim student version. I ran it a couple of times just messing around with it, however, now that I need to use it for my circuits class it is not working. When I start the program it asks me if i want to create a new file, I click yes, then the background is black and does not look like the version I use at school. Also, there are none of the normal components to use in order to draw a circuit, i.e. resistors, ground, voltage sources, etc. Not sure what is going on. Any assistance would be greatly appreciated. Thanks
03-11-2016 02:25 PM
Hello sgking,
I think that you are opening another software that is called NI Ultiboard that is part of the NI Circuit Design Suite (Basically a bundle of NI Multisim and NI Ultiboard).
However you can find Multisim in the National Instruments Folder under the Windows Start Menu (I am assuming you are using Windows).
However you can use the NI License Manager (software to manage licensing of NI products), to verify if Multisim is installed.
If this is not the case can you attach a screenshot of what are you seeing?
03-13-2016 07:02 PM
That was it. Thanks for your help and the quick response.
03-14-2016 10:30 AM
Sure! Just Remember to makr the forum post as resolved!
