05-19-2010 12:43 PM
I need an 8 pin OP Amp model..all the models that I can see in multisim are 5 pin models..but can I get an 8 pin model from somewhere? Could someone please advice?
05-20-2010 02:11 AM
05-20-2010 02:35 AM
If you see http://www.technologystudent.com/elec1/opamp1.htm..... an actual OP Amp has 8 pins.. pin 5 is unused..but I need a model with all 8 pins? Is it available? If not could you please point me to a 7 pin model that uses BJTs?
Thanks!
05-20-2010 03:18 AM - edited 05-20-2010 03:24 AM
05-20-2010 03:32 AM
05-20-2010 04:33 AM
Yes, I need a model with 7 pins , if not 8 pins....is there any available in multisim? or can i get one from somewhere else that you know?
05-20-2010 05:02 AM
05-20-2010 09:36 AM
This one has 6 pins :o(..... could you suggest any other? Im specifically looking for one using BJTs..
Thanks a lot!
05-20-2010 10:32 AM
