12-04-2010 10:45 AM
I cannot find the folder where you can add spice models to the Multisim student edition. When I was using the trial version, I was able to just copy a folder that had spice info for different tubes into the Multisim file that holds all of the models. I can't seem to find it in the student edition. How do I go about doing this? Thank you for any help.
12-06-2010 12:25 PM
PLease?!!!
12-06-2010 12:32 PM
What component are you looking for? I can upload it for you.
The SPICE model you need is likely on the web, Google part number + SPICE and when you find the model create your own component. If you don't know how to do this, refer to this tutorial:
http://zone.ni.com/devzone/cda/tut/p/id/3173
12-06-2010 12:43 PM
I was hoping I didn't have to go through all of that. When I used the trial version at school, we simply downloaded a spice model and copied it into the multisim file that holds all of the models. I was then able to access it and use it to build a circuit. Is this not possible with the student edition? I primarliy work with tube amplifiers, and after purchasing the student edition was sad to see that there are only a few tubes. I would hate do have to go through all of that for every tube I need to use.
12-06-2010 12:49 PM
The Student Edition have fewer components than the Education Edition and unfortunately, you have to add the model.
12-06-2010 01:06 PM
That is very sad news....Thanks for your help. I'm sure I'll be back when I get to trying to add components!!
