06-01-2010 03:55 AM
in my circuit I use the switch ADG1433. After getting the symbol and model from the company i tried to make some sample circuit to test the component.
But i get the following error: Can not parse parameter name
I dont anderstand this error and I hope someone can help me.
06-01-2010 09:35 AM
At a quick glance, that looks like it might be an IBIS model? The SPICE simulator won't be able to simulate that. You will need to get the company to give you the SPICE model for the component instead and recreate or edit the component to use it.
If you edit the component to replace the model, you will need to do that from the database manager, since the edit model window in the component properties isn't available if it can't find a valid SPICE model.
06-02-2010 04:50 AM
Thanks for your help, but I was calling the company and they said that for this component don´t exist a model! ;(
