Multisim and Ultiboard
555 timer causing my counter to start at 20 seconds
I'm building a timer and it works perfectly using a signal generator for the clock pulse but when I added a 555 timer to it the counter always starts at 20 seconds. I am trying to attach the schematic but for some reason it wont attach.
(3,985 Views)
I am trying to attach the appropriate files.
(3,980 Views)
Maybe the 555 is generating unexpected pulses at the beginning which causes the timer to jump ahead. You could use a simple switch to enable the output of the 555 after a while when we know it’s stable.
Check the attached file as a reference.
AGJ
(3,915 Views)
hello guys.
I have it opened in MS14.
It works OK and begins to count almost immediately - the first pulse is little longer than other but not for much.
take a look at the attached picture -
it seems to me the problem is with PC system and not with schematic.
with hope it helps
thanks a lot
Michael
(3,890 Views)
