01-13-2011 07:51 AM
Hi all,
Just a quick and relatively simple question. Where can i find a 4033 IC in the parts list. What i'm after is a
decade (divide by ten) counter with 7 segment decoded output(synchronous). Or an equivalent.
If anyone can help it would be great. And if it is a different type to the 4033 then perhaps a simple explanation
of the connections when copmpared to the 4033 might be needed please 🙂 The model or parts code i have is
CD4033BE H9922BQWN
Many Thanks
Rob
01-18-2011 09:55 AM
Hi Rob
Unfortunately the part you require is not already in the Multisim database.
Multisim has the functionality of users being able to define their own components.
There is a wizard which is easily the most straight forward way of adding a custom component.
This can be found in tools under component wizard. It will give you a step by step guide to create a component. Which you can then use in your designs.
