Multisim and Ultiboard Idea Exchange
otarva
Automatic exporting of analysis results and discarding of exported results.
Status: New
I'd like to have an option for automatically exporting simulation results to a selected file format, including automated resampling to a desired sampling rate. This is related to this previous idea. Preferably Multisim would also automatically discard the exported results from the memory.
I'd like to be able to set a large number of simulations to run, possibly including a wide range of parameter combinations through the parameter sweep analysis, and have the simulations run and be automatically exported to a selected output format without user interference.
Due to the memory handling issue I mentioned in the post linked above, I can currently only run simulations one by one manually saving the results in between. With an automated export I could leave the computer to run the desired combinations during nighttime and have it discard the exported results from memory, allowing the next set of simulations to run.
