Multifunction DAQ
x series ground and shield wiring
Hi all,
W
In our group we are discussing how to best avoid ground loops in our AO signals. We would like to use a PCIe-6363 X series device and I would be interested to learn exactly how the grounds are wired on the device. I found an old reference about the wiring of the grounds in M Series, E Series and S Seriesdevices:
http://digital.ni.com/public.nsf/allkb/02A451C0A88A3EAE8625702F0059C98E?OpenDocument
Is the wiring for the X series devices the same? How are the grounds connected to the PC-ground, directly or via a resistor? What about the shielding of the cable?
Dixie
(3,876 Views)
Unfortunately I can't help, but I imagine that you'd be more likely to get a response if you contacted NI directly. I've had some luck with the "Ask an engineer" link on the bottom right of the service page. Best of luck!
http://sine.ni.com/psp/app/doc/p/id/psp-931/lang/en
(3,841 Views)
Hello Dixie,
I have just noticed that this forum post doesn't seem to have received a reply.
Can you let me know if this question is still active?
Thanks in advance!
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,515 Views)
