What kind of Wi-Fi adapter are you using? Are you connecting to it via USB Raw VISA commands, or can you use the TCP/IP VI's? Where are you getting the device command set and functions? Are the functions distributed in dll's?
Generally, if you have a wireless adapter that can connect to a network, you should be able to use the TCP/IP or UDP commands in LabVIEW to communicate through the adapter to the rest of the network. Check out the LabVIEW example programs in the example finder. Navigate through the example hierarchy to All Examples>>Networking>>TCP & UDP. That set of VI's may get you started down the right track.
Finally, you may get more traffic on this thread if you posted it in the LabVIEW forum. The topic of this thread has nothing to do with multifunction DAQ.
Cheers,
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
