Multifunction DAQ
windows 7 embededd
Is it possibile use the cDaq device connected in a  embedded pc with an embbeded operating sysytem?
I would like use one cdaq like NI9191 with the DI  module(Ni 9425) in embedded computer where is installed windows 7 embedded standard.
Can i use the traditional Daqmx 14???
Is there a document for get some explanation for do that??
Thank in advance.
(3,966 Views)
the only thing you can do is try. There is no official compatibility as you probably have already seen here http://www.ni.com/download/ni-daqmx-14.5/5212/en/.
But most of the time drivers that works for win 7 works also for win 7 embedded.
Regards
(3,932 Views)
Are there any news on the windows 7 embedded compatibility issues?
Thanks marcello
(2,289 Views)
