Multifunction DAQ
what if i connect a differential low impedance source with bias resistors
Will i have an influence to the measured signal if i connect a differential low impedance source (10 Ohm) with 100k bias resistors?
(3,526 Views)
Yes, however you have to ask Kirchof and yourself wether it will matter you or not.
Greetings from Germany
Henrik
LV since v3.1
(3,498 Views)
