10-27-2014 05:11 AM
I am running a digital output module on Labwindows/CVI 2012 (version 12.0.0) and I got the following error (I couldn't any reference for this error status code):
"Function DAQmxCreateAOVoltageChan: (return value ==-201003 [Oxfffceed5])
Device cannot be accessed. Possible causes:
Device is no longer present in the system.
Device is not powered.
While running following code:
ErrDAQmxAnalogOutput (DAQmxCreateTask("",&taskDynamicGeneration),30);
ErrDAQmxAnalogOutput (DAQmxCreateAOVoltageChan(taskDynamicGeneration,SignalConfig.chan,"",SignalConfig.min,SignalConfig.max,DAQmx_Val_Volts,NULL),31);
No change occured on hardware while running and this error doesnt always happen (intermittent problem, I don't know why), so that I cannot identify any cause for this error. Could you help?
Thank you
10-28-2014 04:55 AM
Without all your code, it's difficult to determinate the root of the error.
I advise you to run an example of LabWindows/CVI
To find it, check the different screeenshot bellow and tell me if this error appear again.
Best Regards,
10-29-2014 07:36 AM
It worked fine with this example.
It appeared that we actually had an hardware problem on power supply when switching some relays and this error I have logged could be a consequence of it. I solved the power supply problem and did not reproduce this problem. I hope this would be solved so!
Thank you very much for your quick reply and advice!
