How do I program a two-channel AO that is exactly in sync with a two-channel AI (using NIDAQ 6.9 within Visual Basic)?
I thought it should be enough to just trigger both AO and AI off the same pulse, since both derive their update/convert pulses from the common master clock - but it turns out that usually either AO or AI runs a bit faster than the other than this way.
I had also tried the approch by deriving the AI convert signal from the AO update pulses by using the PF5 line - but without success.
I am using a PCI-MIO-16E4 or alternatively a PCI-6110 board.
Any ideas?
Thank you,
Tilman
