My PCI 6035e board cannot support simultaneous input/output in matlab, unless I convert the transfer mode of the input to 'Interrupts' rather than 'DMA' (Direct Aemory Access). (This is a recognised issue on the matlab website, and is because this board only has a single DMA channel.) So, it's not a problem. However, if i try to use Simulink, the issue raises its ugly head again, and I am unable to get the card to produce simultaneous input and output. Also, I just noticed that the (expensive) USB M series card I was considering purchasing has no DMA channels at all, and so is potentially useless for me.
So my main question is this:
Can i get a NI card which (definitely!) will produce simultaneous input and output in Simulink?
Related questions:
Is there an NI card (USB or PCI) which has dual DMA?
Do I actually need dual DMA at all, or is this issue a red herring and only applicable to the e series boards, as hinted at in some forums?
any answers greatly appreciated
Raymond
