Multifunction DAQ
simultaneous AO & AI on PCI 6010
Hello! Can i make simultaneous, continuous AO and AI on the board PCI-6010 at the same frequency or different frequencies with the help of ANSI C? And change AO signal during AO process? Thanks!
(3,631 Views)
There is little contradiction in your question and it definitely requires more details.
Are you looking to start AI and AO at same time and at same sampling rate?
What aspects of AO are you looking to change? Waveform type or frequency….? If yes, then how are you envisioning to synchronize AI and AO?
What is your overall application and what are you trying to achieve? Also listing specific systems specs(sampling rate, desired sync timing etc) would help as well.
Lastly, have you seen DAQ C examples? To be more specific check out synchronization section
http://digital.ni.com/public.nsf/allkb/FB26BDA52FFFD4EE86257124005C36C3
(3,608 Views)
