05-17-2012 03:04 AM
Hi all,
I need to perform several measurments with this sensor through the analog output and I use the module ni9215. I have created a task and the signal is saturated: I got a constant signal +10.1V. Is the ni9215 the right module for the specified sensor?
05-21-2012 06:10 AM
The NI 9215 is an Anolog Input/Output Module +-10V and so it is ok for every input in his range.
Which kind of tasj have you create? Have you link the D-Series Inclinometer with module directly or by a series resistance?
It seems like a bad connection or task that you are used.
Giuseppe.
05-21-2012 06:21 AM
Thanks for your reply. Here the inclinometer spec:
When the sensos is not power supplied, I get a very low voltage signal, instead when it is, I get a signal saturation. I defined a continous sampling task.
05-21-2012 07:21 AM
Can you export the task and insert as attached file here?
05-28-2012 02:05 AM
Have you resolved your issue?
05-28-2012 06:33 AM
I'm sorry for the delayied reply, but my coworker is keeping the laptop with Labivew and so I can't show you the task. Tomorrow I should get it back.
Anyway is the sensor compatible with NI9234, too?
Best regards
05-28-2012 08:37 AM
as I wrote the module is ok for the sensor but you have to check the connection between module and the sensor in order to read the right signal.
Best regards.
05-28-2012 11:24 AM
Before to connect the sensor to the ni9215, I have connected it to the ni9234 and I'm little bit afraid I have damaged the sensor with it. Is it possible?
05-28-2012 11:43 AM
Are you using 9215 with screw terminal or with BNC?
05-28-2012 01:19 PM
I'm using the ni9215 with the screw terminal.
