03-16-2015 09:23 AM
Dear All
I have a SCXI-1000 with scxi-1600, and many time ago I had a problem with it and in that time was the inside fuses.
Now the problem is different, the SCXI-1000 has power, the SCXI-1600 has the 2 v+ and v- led turned on but the ready led no.
I tryed with other SCXI-1600 and the system is recognised as normal, seems everything ok with scxi-1000.
I opened the scxi-1600 but has no signal that has a fuse inside.
Any suggestion
Best regards
cpalha
03-23-2015 04:25 AM
Dear All
No ideas please.....
cpalha
03-23-2015 11:26 AM
Hi cpalha,
If you can swap in the second 1600, without changing anything else, and the system works properly, then the first 1600 is likely in need of repair. A few things that you might try first:
If none of these steps lead to a change in behavior of the module, please contact your local branch to set up a repair for your device.
