10-20-2014 10:11 AM
Hello everyone,
I've been using NI hard- and software now for some time and never had such a problem. I'm going to measure a load-cell connected via a SCC_SG24 on a SCC-68 to an PCI-6229. I have set up everything according to the respective manuals. But when setting up a test-task and choosing to measure analogue signal -> Force (Bridge) it shows, that no supported hardware is installed. The computer I'm using has only installed LV-Runtime (because it's a production computer) and DAQmx.
Could anyone tell me, whether I'm using the right components for the task and/or why it is not showing up in the task. When choosing "voltage with excitation" in the task creation window I can choose the SCC-SG24 channels. Do I have to install the LV Development environment to use the strain measurements?
Thanks very much in advance!
Mateusz
10-27-2014 07:38 AM
hello,
I hope I can help you with this docuement:
Strain Measurements With Strain Gages: How-To Guide - National Instruments
http://www.ni.com/white-paper/7130/en/
best regards
Richard
10-31-2014 03:09 PM
Hi Mateusz,
I don't think the issue is runtime vs dev environment. I've simulated a 6229 with an SCC-68 and an SG24 on a computer with the full development environment and I can only do Strain, Voltage and Custom Voltage with Excitation tasks on the SG24.
I don't know of any reason that it wouldn't be compatible with Force-Bridge tasks. My hunch is that the Force-Bridge task wasn't around when SCC first came out.
I'll dig and let you know if we find out more.
Luke B.
NI R&D
10-31-2014 05:20 PM
thank you both for your help. The guide was helpful, at least I know now that the SCC is correctly installed.
I would very much appreciate it, if you could find some more information, because the force-bridge gui seems to make setting up the load cells pretty comfortable.
Mateusz
11-17-2014 01:17 PM
Update:
After some weeks of waiting NI contacted me again and explained, that this is really a driver matter. They have created a corrective action request so maybe it will find it's way in future releases of the DAQ drivers.
Thanks everyone for your help.
Mateusz
