I do not completely understand what you want to do. I'm assuming that you mean you would like to save the array into a file, and then read it back later. If this is the case, take a look at this example:
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3DF5556A4E034080020E74861&p_node=DZ52146&p_submitted=N&p_rank=&p_answer=&p_source=External
I hope that helps!
Derek
