Multifunction DAQ
read bipolar voltages in the 20 volt range with E series card
I tried placing the value -1 in the gain parameter in the AI_Read function, but it didn't work. Instead of returning 6.3V it returned 5 flat.
(2,216 Views)
Robin,
Are you using the AI_VScale function to scale the binary data returned by the AI_Read function? If you are, you need to be certain that you are also correctly specifying its gain parameter. Below, I have attached a simple example that appears to function correctly (Modified AIonePoint.C).
Good luck with your application.
Spencer S.
(2,216 Views)
You are right, I'm not using AI_VRead directly, instead there's another function "wrapping up" this one. In the new function the gain parameter is not being passed to the AI_VRead in the intended way. I have done some preliminary changes and I have seen it work.
(2,216 Views)
