Hallo all,
What I want to do is, to draw connected lines on a graph using just the mouse...
First I will define min and max values for (x,y) -graph range- using the property node...
Then using the mouse I want to draw frequency ramps over time like in FMCW modulation... For example it will just draw the ramps by connecting several points marked by my mouse clicks on the graph. Moreover I need the (x,y) values that I click on the graph...
Ogulcan
