12-17-2014 07:35 PM
I am recording the output of a function generator (~15mV sinusoids at ~3000 Hz). I am using a BNC to direct the signal out of the function generator and into the BNC2090A and recording the analog signal in SE mode. While the data starts out being close to 0 in diff mode (fig 1), it drifts towards -10V as soon as i shift the recording to SE mode (fig2 ). Finally after ~ 5 minutes, the voltage eraches its minimal value and levels off (fig 3)
Whats happening?
Board: PCIe 6363
PC: Dell optiplex running Windows 7
DAQ Interface: BNC 2090A
Only AI0 is connected. Every other BNC slot is empty
I checked the output of the function generator using an oscilloscope - it is pretty stable over many hours.
Balaji
12-17-2014 09:35 PM
12-17-2014 10:45 PM
Thanks for the reply.
I am recording in RSE mode(if that is what you are asking)
12-18-2014 12:55 AM
12-18-2014 06:41 AM
What Dennis is trying to get at is that if you are using RSE configuration, you need the ground of your signal to be connected to AI GND.
