01-29-2006 01:05 PM
02-22-2006 09:00 AM
Hi Jos,
The extlib in CVI is for use with external compilers, this contains all symbols that any external compiler would need to resolve any function calls.
the library from the NI-DAQmx folder is optimized for use with MSVC and does not contain these simbols.
Hope this helps.
Karsten
09-18-2014 11:20 AM
I have a similar 'external compiler' linking problem with the nidaqmx library. I purchased a NI DAQ and installed nidaqmx v14. I successfully compiled a C++ application using msvc 2013. However, when I try to compile the application using the open source compiler, gcc to create an oct file under Octave similar to above Matlab process it compiles but I get similar linking errors:
octave:8> mkoctfile AcqIntClk.cc
AcqIntClk.o: In function `Z10FAcqIntClkRK17octave_value_listi':
c:\Octave\Octave3.6.4_gcc4.6.2/AcqIntClk.cc:67: undefined reference to `DAQmxCreateTask@8'
c:\Octave\Octave3.6.4_gcc4.6.2/AcqIntClk.cc:68: undefined reference to `DAQmxCreateAIVoltageChan@40'
c:\Octave\Octave3.6.4_gcc4.6.2/AcqIntClk.cc:69: undefined reference to `DAQmxCfgSampClkTiming@32'
c:\Octave\Octave3.6.4_gcc4.6.2/AcqIntClk.cc:74: undefined reference to `DAQmxStartTask@4'
c:\Octave\Octave3.6.4_gcc4.6.2/AcqIntClk.cc:79: undefined reference to `DAQmxReadAnalogF64@36'
c:\Octave\Octave3.6.4_gcc4.6.2/AcqIntClk.cc:90: undefined reference to `DAQmxGetExtendedErrorInfo@8'
c:\Octave\Octave3.6.4_gcc4.6.2/AcqIntClk.cc:95: undefined reference to `DAQmxStopTask@4'
c:\Octave\Octave3.6.4_gcc4.6.2/AcqIntClk.cc:96: undefined reference to `DAQmxClearTask@4'
collect2: ld returned 1 exit status
I tried to copy all of the nidaqmx lib and include files I could find into the Octave lib and include folders. The Extlib and include files and under C:\Program Files (x86)\National Instruments\Shared\CVI appear to be deficient. Can you please help?
09-18-2014 01:15 PM
Update: I did find some more complete lib and include folders under
C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C
But when I copied them into my Octave (gcc) lib and include directories I still could not link (undefined reference to ....)
