Multifunction DAQ
ni usb 6210 not "accessible"
I am trying to connect and have accesible through LabView 2016 NI USB 6210 device. I am running Labview 2016 tral version, win 7 home edition premium 64 bit system. I can see the device through NI- DAQ 16 , i can do self tests and what not but at the Instruments VI in Block diagram , I do not see this particular device. When I try to connect the device, through Tools /Instrumentation/Find Instrument drivers, I see only an an unidentifiable device. How do I make labview to list the device VIs so that I can have access to the ports? Am I missing something?
It has been a long time since ia have used Labview last (6 years+). My previous experience was with USB-6525 device. I was thinking that the above two mentioned devices have similar operation and access , am I correct?
(2,940 Views)
Hello tony7a,
What was installation order of LabVIEW and DAQmx drivers? We always recommend to install LabVIEW first and then drivers: http://www.ni.com/download/ni-daqmx-16.0/6120/en/. A reinstallation of the drivers could fix the issue.
If you se the device in NI-MAX you should be able to use it in LabVIEW. I recommend you to use DAQ Assistant as a starting point to check if the device/ports are available: http://www.ni.com/tutorial/4656/en/
Then you can use the DAQmx Palette to create more versatile code: http://www.ni.com/product-documentation/2835/en/
(2,905 Views)
