06-16-2005 03:33 PM
06-17-2005 02:15 PM
06-17-2005 05:05 PM
07-15-2005 04:26 PM
07-18-2005 11:52 AM
Hi Jeff-
Just to verify, I assume you're using the PCMCIA in a laptop PCMCIA slot and not a PCI to PCMCIA bridge. The latter configuration is not recommended because of some compatibility problems between the data transfer mechanisms of the two different buses and reliability problems with some converters.
Also, you might have already noticed this but the card is not supported by the most recent version of the NI-DAQ driver for PC under Win98. For 98/ME you will need NI-DAQ 7.1
If you plan to use either WinXP or 2000 you will need NI-DAQmx 7.5 to be up-to-date with the most recent version. I would suggest updating to this version to see if the problem persists. Make sure that you physically uninstall the card before uninstalling your old driver version and installing this update. Then reinstall the card after powering down and check for problems when you start back up.
If the problem still exists after this I would suggest attempting to use the card in other machines and also to test with the various other conditions such as removing unnecessary devices from the system as outlined in the KnowledgeBase that Lesley originally suggested.
I hope this helps!
Thanks-
