Such a set up is not recommended. Some of the drawbacks are:
- Depending on how you plan to multiplex the signals together (SCXI/PXI switch, 3rd party mux), you could very easily be introducing noise to your system.
- Multiplexing the signals together into one line limits your sampling rate to the switching speed of you multiplexer device.
- You will probably need to spend more time developing handshaking schemes in order for switching and acquisition to occur in such a way that you don't miss signals that you want to acquire.
These are only some of the drawbacks to this setup. All in all, the only functionality of the 4472 board that you would be left with is it's ability to sample all eight channels at the same time. So, you
could multi
plex all the signals together, but doing so is
not recommended.
However, I have a couple of questions. Do you want to sample all 64 sensors at the same time? Assuming that you are not, how are you planning on multiplexing the signals together? What kind of a chassis are you working with? Please let me know.
Logan S.
