Multifunction DAQ
input and output differ
"Have you tried using a different cable to connect the output to the input?"
   This is vague... why would I do that?  analog scope shows correct.  what different cable do you suggest?
Message 11 of 14
(1,890 Views)
I apologize for being unclear.  What I meant to ask is: have you tried using a different BNC cable to connect ai0 and ao0?  I want to rule out that the BNC cable is faulty.
Message 12 of 14
(1,857 Views)
I have many cables.  as I have stated (whatever cable I use) the external scope shows what I expect the DAQ does not.
Message 13 of 14
(1,837 Views)
Do you experience the same incorrect signal behavior on all of the analog inputs?
Message 14 of 14
(1,815 Views)
