Hi Romain.
In your DAQ vi, you are writing file essai.dat as
1D array of I16 (1 array per scan)
When reading it, you try to read data as DBL, and that is not correct.
There are different choices. The easiest one: use high level vi to read I16 data as 2D array.
I tested for 5 channels and it works.
Don´t know your Lv version, so see attached doc.
Hope it helps
Alipio
"Qod natura non dat, Salmantica non praestat"
