Multifunction DAQ
how to use hardware-controlled serial Digital I/O in reading
I use visa to programe.
my code as follows;
include......
include......
iBus* bus;
bus = acquireBoard(0x10931180);
tAddressSpace Bar1;
tESeries *board;
tSTC *theSTC;
int i;
initMite(bus);
Bar1 = bus->createAddressSpace(kPCI_BAR1);
board = new tESeries(Bar1);
theSTC = new tSTC(Bar1);
theSTC->DIO_Control.writeDIO_Pins_Dir(0xf7);
theSTC->Clock_and_FOUT.setSlow_Internal_Timebase(1);
theSTC->Clock_and_FOUT.setSlow_Internal_Time_Divide_By_2(1);
theSTC->Clock_and_FOUT.setClock_To_Board(1);
theSTC->Clock_and_FOUT.setClock_To_Board_Divide_By_2(1);
theSTC->Clock_and_FOUT.flush();
theSTC->Clock_and_FOUT.writeDIO_Serial_Out_Divide_By_2(1);
theSTC->DIO_Control.writeDIO_HW_Serial_Timebase(0);
theSTC->DIO_Control.writeDIO_HW_Serial_Enable(1);
if(theSTC->Joint_Status_1.getDIO_Serial_IO_In_Progress_St()==1)
ShowMessage("Serial IO already in Progress");
//int i=0;
w=theSTC->DIO_Serial_Input.readDIO_Serial_Data_In_St();
Now I can write,but I can't receive anything. There is no extstrobe/sdclk too.why?
Thank you!
(2,513 Views)
Hi bluesolyg,
It seems like you're doing Register Level Programming..is that the case? If so, you should post your question in the following thread here.
Lesley Y.
(2,461 Views)
