10-30-2014 10:23 PM
Hi everyone,
I have problem finding the suitable function to save data into txt or TDMS like queue or stack. Could anybody show me some sample to save data like that?
The data is generated in a while loop and the data is saved outside of the loop. In the past, I used "build table" VI to add data generated in each loop into the table and save them all in the file after the while loop is over. However, the "build table" VI is time consuming and it is executed for every loop thus slowing down the speed of the program.
To increase the efficiency of the program, I am now using a shift register and stack structure to add all the data into a stack and save them all in the file after the while loop is over. This method is still consuming some time.
I hope I can use a function to save file in a way like stack so that it can save data generated from each loop outside the while loop, and it can add the new data to the end of former data without overwriting the former data. Is there such function to do so?
best
10-31-2014 03:59 AM
10-31-2014 08:34 AM
Dear crossrulz
I know the structure of producer/consumer. Actually I want to find a data saving VI that will add the new data behind the former data without overwrite it. The "build table" VI is actually doing such thing but it is time consuming and it needs to work inside the loop. Is there any VI can save the data outside the while loop? Do you have any suggestion?
best
10-31-2014 11:36 AM
Take a look at this quick example
11-01-2014 12:05 AM
Dear
Can you save the file in early version of Labview? I am using Labview11 and I can not open this file.
Thanks very much!
best
11-03-2014 01:48 PM
OK.
