Multifunction DAQ
how do you create ai/StartTrigger in multi function synchronization?
In the simultaneous start example under Multi-function synchronization how do you configure the ai/StartTrigger thing in the VI “Get terminal Name with device prefix VI”.  How do you create this in Max?
Possible reason(s):
Source terminal to be routed could not be found on the device.
Make sure the terminal name is valid for the specified device. Refer to Measurement & Automation Explorer for valid terminal names.
Property: Start.DigEdge.Src
Property: Start.DigEdge.Edge
Source Device: Dev1
Source Terminal: Device=ai/StartTrigger
Task Name: _unnamedTask<10>
[+] Enlarge Image
Figure 2 Simultaneous start example
(3,956 Views)
Are you sure your device supports digital triggering?
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,943 Views)
yes . i forgot to mention the hardware part. it is USB multifunction DAQ 6218. i am working in labview 8.5.
(3,925 Views)
How are you configuring the trigger?  The proper terminal name should read:
/Dev1/ai/StartTrigger
You are currently trying to set the terminal to:
Best Regards,
John Passiak
(3,919 Views)
