07-23-2005 12:44 AM
07-25-2005 12:12 PM
The easiest way to perform a certain action (such as file I/O) based on a certain condition (such as whether a value has passed a certain threshold) is to use a comparison VI in combination with a case structure. Then you can specify that if your rms, standard deviation and variance are above a threshold then perform a certain action.
Also consider using shift registers to keep track of data from the last loop. If I understand you correctly, you want to start logging data when an upper threshold has been passed. Then you want to continue logging data until a lower threshold is passed. I have attached a non-functional but explanatory VI that will help explain how to implement logic to that effect. It also demonstrates that you can indeed write and read from the same file in a loop. The best way to do this is to open the file before the loop, do all the necessary writing and reading in the loop, and then close the file after the loop.
Hope this helps!
