04-14-2014 03:44 PM - edited 04-14-2014 03:46 PM
Hello my question is if i can use Lab View together with a homemade DAQ device that doesnt have any drivers.Will Lab View atutomatically connect to it? It has 6 analog channles and ill use it for measuring temperature thermocouples.
04-14-2014 05:24 PM
04-15-2014 01:44 AM - edited 04-15-2014 01:52 AM
It uses USB port. Can you give me mroe details how exactly can i make the driver?
04-15-2014 07:32 AM
04-22-2014 03:46 PM
Now to clarify things... i am using the EMANT 300 USB DAQ Module and i have drivers installed for it, but the application adapter is custom made, totally different it has more analog channels, how do i make it work together with labview?
04-22-2014 04:08 PM
04-22-2014 04:19 PM
I have used the EMANT device and the LV Driver in the past.
Please post some details of how your adaptor connects to the EMANT and what you want to do.
Lynn
04-22-2014 05:29 PM
The Adaptor will connect to the Emant via the DB 25 pin connection. The adaptor has more analong input channells, and i will use it to to measure temperature with 6 thermocouples measuring at the same time. I will create the program via the DAQ assistant in LabView and the assistant should show me all the available inputs of the device. Right now it doesnt because Lab View don't recognize the DAQ hardware. The Adaptor is custom made and i need to make it work somehow together with Lab View.
04-22-2014 05:36 PM
04-22-2014 05:44 PM
As Dennis said, you cannot use the DAQ Assistant. It only works with NI DAQ devices.
Use the EMANT VIs.
What functions on your adapter connect to which pins on the EMANT? Telling us that your used the 25-pin connector provides no useful information.
Lynn
