08-30-2015 06:09 AM
Solved! Go to Solution.
08-30-2015 08:51 AM
First, it is helpful if you name the manufacturer of the sensor. A part number alone does not mean anything to most of us. Are you using the Pepperl+Fuchs fiber optic sensor? Even better is to post the datasheet/manual of the sensor or links to them.
The datasheet I found for the Pepperl+Fuchs sensor is not very well written, in my opinion. It appears that the outputs are pulses with amplitudes dependent on the power supply voltage and frequency or timing set by operating mode.
If that is the device you are using, the only way you have any chance of decoding the outputs with the USB-6008 is to measure them with an analog input and then process the data in software. Depending on the power supply voltage, you will probably need a voltage divider to reduce the sensor output voltage to a level compatible with the DAQ device. You also will not be able to use the high speed mode of the sensor because the pulse rate exceeds the Nyquist limit. In standard mode you mighte be OK but you can only use one channel of the USB-6008 to stay within the Nyquist limit.
Lynn
08-30-2015 09:29 AM
08-30-2015 04:36 PM
As Johnsold alrady stated your output signal is a 24V digital signal (to sensor GND/ 0V) .... so depending on what you want to measure you need to reduce the voltage output.
So what do you want to do? And how fast do you expect the signal to change?
To bring the signal down to a secure level I would propose this circuit:
it will limit the output voltage to 2 times the LED voltage , red LEDs have about 1.8V , so you end up with 3.6V pulses you can measure savly with any 6008 input.
As an additional benefit you get a visible indicator 🙂
for slow detection (software timed) use a digital DIO pin
faster is the analog input
for very fast counting you can use the PFI0 counter.
AND VERY IMPORTANT: you need to connect the sensor supply 0V to the 6008 GND, sorry missed that in the diagram.
08-31-2015 01:10 PM
Henrik,
Thanks for the detailed explanantion.
Lynn
08-31-2015 03:04 PM
08-31-2015 03:54 PM
No, but I hope it helps the OP.
Lynn
09-01-2015 10:32 PM
Thanks a lot Henrik & Johnson.
Looks like details enough info for me to complete my task. Let me try this circuitry on coming Saturday & feedback to you all for the results. Agains, Thanks a lot & pls waiting for my feedback.
09-06-2015 11:16 PM
Hi Johnsold & Henrik,
I am back for good result.
The idea & diagram provided help me a lot to reduce input voltage pulse & able to measure the pulse on Labview USB 6008.
I just play around the freq. in order to capture perfect pulse.
You may see the pics attachement.
Now, I am going to calculate rpm from the pulse.
Thanks a lot Expert.
