Multifunction DAQ
error -50103 from DAQ read?
I have a PCI6013 daq card and 3 RTD modules occupied channels 0 to 2 on SC2345. If I have another voltage input, how can I configure it in DAQ assistant.
I got error -50103 all the time no matter which channel is set. It works fine if subvi runs individually. But got error message when called it from a main vi.
the error message is "Possible reason(s):
The specified resource is reserved. The operation could not be completed as specified.
Task Name: _unnamedTask<91>"
I am wondering what's wrong with my program?
Thanks.
(4,159 Views)
Thank you for contacting National Instruments.
It sounds like you are trying to access resources which are already in use by you main VI. If you have a task running which is performing analog inputs (AI) and you try to open another task doing AI (even on different channels), this error will occur.
Please see the following Knowledge Base for more details: http://digital.ni.com/public.nsf/websearch/04BEDD9E9E91ED3486256D180048116D?OpenDocument .
Let me know if you have any further questions.
Sincerely,
Sean C.
(4,152 Views)
Hello what should be done in this shipped example with the same problem?
Berns B.
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
(3,772 Views)
Hi Berns-
Please see my response here.
Thanks-
Tom W
(3,768 Views)
